What should the angle indicated by the red lines be?
I was thinking it should be 90 degrees or larger but the repro mounts I have are smaller. I haven't measured but I put a square on it and it looks like the repro is about 85 degrees. It looks like the floor pan is sloped from the middle to the outside of the cab; higher in the middle and lower at the sides. The repro mounts being less than 90 degrees just doesn't seem right. Wouldn't that cause it to slope to the inside? My originals are not in good enough shape to trust the measurements.
