Pulling a trailer with 240 6.
Pack Rat
Post by Pack Rat »
Anyone here pull a trailer with a little 240 L6? My truck is just a 100 stock with floor 3 speed conversion. I have a small camper I built to pull behind my Galaxie.Want to use the truck to pull it this fall to haul gear in the back. Trailer probably weighs 1200 pounds. No brakes. It is basic with place for storage and 2 beds.
1966 F100 240 3speed
1968 F250 Camper Special 390 C6 with 70 Sells slide in camper
1964 Galaxie hard top. 390 dual quads
1962 Falcon soon to have 428 4 speed and straight axle.
36truck
Re: Pulling a trailer with 240 6.
Post by 36truck »
It should be fine pulling that trailer. The 300 6cyl. is a good torque monster. You 240 will be slow but still get the job done.
Tom Williams
ras4434
Post by ras4434 »
I pulled a similar trailer with my 66 that had a 300 for 10+ years. Give your self extra breaking space, make sure the brakes are in good shape and take it easy. Takes longer to stop so be careful. That said have a lot of fun. these trucks are work horses.
Ross Swearingen
1965 F100 "MIKI"
1965 F100 4x4 looking for a new home
Mr. Jones
Post by Mr. Jones »
Have you thought about just hooking it up and driving locally,up a few hills,get up to speed check the brakes etc.
shortwide
Post by shortwide »
Your main limitation will the top speed you can attain....not whether the 240 will pull it. It's a torquey little sucker and will easily pull it along, it just may not want to run at interstate speeds.
So your choice of roads/route will be more important than anything else.
Don
'66 Styleside Shortbed, I6, Original Paint Survivor
'54 Ford Mainline Tudor, 302/AOD, disc brakes
'54 Ford Club of America
http://www.1954Ford.com
Lowell
Post by Lowell »
If you could swap out the tranny for a four or five speed,that would help you get moving.
Pack Rat
Post by Pack Rat »
Ok sounds good. Will take it on short drives. Just redid front brakes Saturday and installing a power booster this weekend. 4 or 5 speed in future. not sure which yet. First trip will be less than an hour. Galaxie pulls it 80 mph no problem. 8)
shortwide
Post by shortwide »
That trailer is awesome looking.
Did you use a set of plans or just create it from scratch?
Don
Pack Rat
Post by Pack Rat »
I bought the empty shell on ebay and then made it mine.
shortwide
Post by shortwide »
I need to do exactly that.
My boys want to go camping in something pulled behind my 66....something vintage looking. And, we wouldn't care if it was bare-bones inside, as long it kept us warm and dry.
Don
Pack Rat
Post by Pack Rat »
It is mostly a bone inside. I have the power inverter from the pop up and the lights. I ran 4 outlets and a 12 power port to charge battery. I have a battery under the seat. The back bed can be a table but I eat out side. Front couch pulls out to be a bed. I bought a new B grade dorm size fridge. No toilet or running water. A/C was a face book find for 50 bucks.
