It appears to line up well at the front, but to me, I think it needs to come closer toward the cab and it looks like it's sitting too high at the back. Meaning it slopes upward at the rear.
Trouble is, where it sits on the rails appears to be correct. If I push the bed any closer to the cab, the angle of the bed at the back gets higher (worse.)
Are the rails between 61-64 all the same? MIne is a 62 and it's never had a styleside bed on it before and to add to the fun, I've had to grind off the 'brackets' that held on the old steel tray so I'm not 100% which holes in the rails were for the styleside bed and which were drilled for the tray.
Comparing to a few others pics, some beds look dead straight along the body line, a few others look like the bend upwards.
Any opinions?
