I have a question about fender bolts...
I ordered a Totally Stainless kit which includes all the bolts for the body.
When I took my fenders off I had to cut the head of the bolts to get them off the car. (the clip on bolt stripped out the fender)
What should I do in this case to bolt the fenders back to the cab?
Also the Rubber pads that the Radiator support sits on are bad... Any ideas?
Question about fender bolts...
Re: Question about fender bolts...
you will have to get new u-nuts, if you do not have a good hardware nearby you can order them online
here is one place
http://www.clipsandfasteners.com/Nuts_U_s/115.htm
rubber pads i would get from flashback f100s
http://www.flashbackf100s.com/home
here is one place
Add to what Iceman said, I'd take a look at replacing the cab rubber bushings. You can use regular nuts on the fender bolts but the U nuts like the factory used are really nice to work with and appear more stock. I often work by myself and those U nots are nice. IMHO!
William-in-St. George
- 65MercTruck
Just came across this thread while searching the forums...
I'm currently in the process of removing the front fenders and core support (65 M100) to begin major body work. ALL of my fender bolts are rusted solid. I've broken a few and will use my torch to remove the rest. What a pain in the...
My question is: Where have you all gotten your replacement fender bolts from? Hardware store? Or is there a decent online F100 source? I don't need a 'stainless' kit, but it sure would be slick if there were a nut and bolt kit available.
If I can get one off intact, I'll bring it down to my local hardware store to match it. I suppose that's my answer, but I figured I'd ask...
Thanks!
Thanks!
1965 Mercury M100
shorty style-side
351W 4spd w/ frnt disc
Dana 44 rear w/ trac-loc
Built in Oakville, Ontario
shorty style-side
- 65MercTruck
Where'd ya get the bolts?cwindsor wrote:I have a question about fender bolts...
1965 Mercury M100
shorty style-side
shorty style-side
The company is called totally stainless they do nut and bolt kits for many applications.
you can purchase anything from bolts for a specific part of your truck to a whole kit and in various head styles I used a kit for cas and I purchased a second kit for my latest project very complete and worth the money
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
460 C6
Ken
- 65MercTruck
Excellent. Thanks for the info!castruck_1964 wrote:The company is called totally stainless they do nut and bolt kits for many applications.
http://www.totallystainless.com/
1965-1966:
INDENTED HEX HEAD 6-6296 309.20
The kit does the entire truck! I'm impressed!
1965 Mercury M100
shorty style-side
shorty style-side
I know how nice stainless stuff is because I have seen Ken's truck.
Very nicely done I must say. AUVECO makes the 5/16 x 18 body bolts that work well to put our trucks together. They also have the clip nuts,
Notice I did not say encapsulated nuts. These clip nuts will slide in where the old encapsulated nuts come out and will work great to assemble your fenders and frontend pieces. They are available at most places where fasteners are sold. They are available in boxes of 25 and possibly more but I didn't check when I bought mine. I would suggest that you use a bit of Anti-seize on your bolts when you put them in. You may never have to take your truck apart again, but if you do it will make it a lot easier. TR
I just saw Mac's add on Evilbay for the bolts in black as original. Sold by the dozen I think. I've bought the other cadmium plated bolts and used those, but quality of the bolts is not up to my expectations. Material is softer , which may or may not matter to some. Personally, I don't like things that strip out easily. However, there are so damn many bolts on the fenders of these trucks, there is no way that a fender will ever fall off. I prefer using nuts and washers to the clip nuts for ease of removal.
