Separate Turn Signal Indicators In Dash Cluster
Has anyone done this conversion to a '66 sweep speedo? If so what did it entail?
- ezernut9mm
Re: Separate Turn Signal Indicators In Dash Cluster
the wiring is already there. ford just plugged them together so either side lit up the one green indicator. you can remove the factory jumper and then you have separate blinkers, but i don't know where you would put the other one. maybe use the high beam as it is exactly opposite the blinker. then do something different for the highbeam indicator.
here is a pic of the jumper used on the sweep speedometer turn signals
if your going the opposite, (sweep to round) you just remove the jumper and use 2 bulb sockets.
its all plug in so no wire hacking required
- ezernut9mm
that's the jumper i was talking about. a picture is worth at least 19 words. lol
