Gauge Pod
- Blackwaterforge
Gauge Pod
- ThinLizzy13
Re: Gauge Pod
Looks nice!
Where'd you get the two gauges that are in your dash?
- Blackwaterforge
Re: Gauge Pod
I bought a instrument panel from a Slick 60's member.
It came from an F-800.
It has tach, vacuum, amp and oil pressure.
- ThinLizzy13
Re: Gauge Pod
Those are pretty cool, but I was askin about the big round ones on either side of your speedo.
Re: Gauge Pod
looks good but wondering about the pyrometer or is there a forge in the bed and thats how you tell its temp
Re: Gauge Pod
ThinLizzy13 wrote:Those are pretty cool, but I was askin about the big round ones on either side of your speedo.
tach and vaccuum gauges from big trucks f500,600 etc.
vac on left, tach on right
theres also a big air pressure gauge for trucks with air brakes
- Blackwaterforge
Re: Gauge Pod
Vacuum left side of speedo.
Tach right side of speedo.
Standard equipment on F-800.
ICEMAN6166 wrote:looks good but wondering about the pyrometer or is there a forge in the bed and thats how you tell its temp
LOL!
Pyro and fuel pressure gauges in preparation of Cummins swap.
- Blackwaterforge
Re: Gauge Pod
I will convert the vacuum gauge to pressure and use it for a boost gauge.
Re: Gauge Pod
Blackwaterforge wrote: in preparation of Cummins swap.
just what you need.
6bt with nv trans
- Blackwaterforge
Re: Gauge Pod
ICEMAN6166 wrote:just what you need.
6bt with nv trans
Ice: I am going to use a 4BT with a borg warner T-19 and a Watson auxiliary.
- ThinLizzy13
Re: Gauge Pod
Are those tachs gear drive? I would like to have a set like that but not sure how to do the gear drive. Did the 332 FE in the old trucks have a dizzy with the gear drive for the tach? Wonder how hard it would be to find all of this stuff. Wonder what it would cost!!!
1965 F100 "Papaw's Pride"
- Blackwaterforge
Re: Gauge Pod
Mellvis wrote:Are those tachs gear drive? I would like to have a set like that but not sure how to do the gear drive. Did the 332 FE in the old trucks have a dizzy with the gear drive for the tach? Wonder how hard it would be to find all of this stuff. Wonder what it would cost!!!
Tach is electric.
I don't know about the FE engines but there was a distributor with a tach drive for the 300 6 cylinders.
Re: Gauge Pod
332,361,391 etc. is not FE but FT there are differences. the tach on those is gear driven off the distributor.
in the salvage yard look for cabovers and bigger trucks to find the FTs
Re: Gauge Pod
Are the FT and FE parts generally interchangeable? Not to concerned since that tach is electrical, but curious.
Re: Gauge Pod
Nice work on the aluminum panel. fits well, like it was meant to go there.
I always thought those tachs were mechanical? Should have paid closer attention!
Re: Gauge Pod
FT dizzy will not fit in a FE block. The base of the FT dizzy gear is larger than the FE.
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
- FORDMANLCRACKEL
Re: Gauge Pod
Look's Good.
Lonnie
Lonnie
Re: Gauge Pod
You can get the tachs electrically driven and higher rpm range from the bronco vendors now. A member on here has done it and it looked great.
Black water forge, did you hook up the vac gauge? I have one but there is no tee on the back of the gauge just a hole?!
Re: Gauge Pod
supposed to be a fitting on the back, takes 1\4" brake line about 6" long then a rubber hose to the fitting on the intake manifold.
