In-cab sending unit
In-cab sending unit
Got the tank pulled and I'll flush it out today but was wondering about the sending unit. I noticed while looking through the catalogs that the new units have a straight rod whereas mine has a slight bend upwards down on the float end. My gauge reads 1/4 when in fact the tank is empty so do I need to straighten the rod or give it more bend upwards? Also, I need to replace the cowl to hood seal and I couldn't find anything in the catalogs for this. Is this item obsolete and not being repopped?
Re: In-cab sending unit
Dennis Carpenter sells the seal. you probably need to replace the sending unit. hook up the wires, and watch the gauge through range of motion, out of the tank, to tell if it works correctly
Are the DC sending units good, I understand they are China made.
I do not know. Tom at flashback f100 won't steer you wrong
DC units are good. Just installed one (my float sank). Rod should be straight. FWIW!
William-in-St. George
the cowl seal is shown here but i would check www.flashbackf100s.com before buying imported rubber parts
