Warm cab = happy wife
Dang old heater wasn't working very good
Putting out a little heat ... Hardly blowing at all
Figured it was plugged up with leaves and dirt...
Colleen not liking it... I'm thinking iced up windows not getting thawed
Pulled it in the shop and pulled heater box out
Hmmmm.... Looks like somebody replaced the motor
Blowed the coil out.... Not too bad there
Put it back together... Tested it... Dam thing doesn't blow much
Hmmmmm.... Wonder if that "new motor" is running the right direction
B I N G O ,!!!
Reversed the two wires coming out (this doesn't work on all fan motors)
But it did on this one ... WAY more air...
Patched up a few holes in the cab with duct tape
(This ain't no show truck)
Put heater box back in
Little cardboard in front of the radiator never hurt anything....
Test drive... SUCCESS !!!
Nice and toasty at 20*
Defrosters work good too
Life is good :bs:
Re: Warm cab = happy wife
Actually meant that BS guy to be a happy face....
But what the heck.... Sometimes life is a little bs
bruceandersson
Post by bruceandersson »
Duck tape rules!
foodstick
Post by foodstick »
As long as you are using the duct tape for hole sealing, and not cab mounts !
foodstick wrote:As long as you are using the duct tape for hole sealing, and not cab mounts !
What ? Do you think I'm that crazy ?
That's what baling wire is for... Much stronger !
Leeroy
Post by Leeroy »
Don't you just whack in some 2x4 for cab mounts?? :lol:
Leeroy wrote:Don't you just whack in some 2x4 for cab mounts?? :lol:
Well.... I have seen that done
I probably do some things that guys might shake thier head at
But I have never... Never never never
Used spray foam on a vehicle :cussing:
Mr. Jones
Post by Mr. Jones »
4x4,
That spray foam makes an excellent door seal,did it to my 350.Ugly as hell,but it's nice and warm inside.
DW
skidoorulz
Post by skidoorulz »
Careful with the cardboard if it right up against the radiator if completely blocked. I have seen radiators pulled right into the fan this way
Leeroy
Post by Leeroy »
That foam could fix some of those troublesome rust issues.... Im surprised it hasn't been sprayed into the later style cab mounts as a poor mans POR15! :lol:
I probably do some things that guys might shake their head at
Don't worry, we're ALL guilty of that from time to time!
I had a carb rebuilt once and the guys who rebuilt it were really complaining about how it had been assembled and some of the parts that were missing, I just couldn't bring myself to tell them it was me....
skidoorulz wrote:Careful with the cardboard if it right up against the radiator if completely blocked. I have seen radiators pulled right into the fan this way
I cut it so it's full width, but about 10" from the top
Also cut a 10" hole in the center
Probably covering about 60% of the rad
I watched the thermostat pretty close at first
Just under 200* ... Just about right
BarnieTrk
Post by BarnieTrk »
I agree - cardboard in front of the radiator is a good way to get these ol' beasts of burden to warm up faster.
A couple of hints that have worked for me along the way:
--- I have spray painted the grill side of the cardboard to slow the cardboard's turning to mush from the snow/rain spray coming thru the grill.
--- In an effort to keep the cardboard from falling out from in front of the radiator, I have cut the cardboard about 2" narrower than the radiator and then slid it down in front of the radiator until it covered about 1/2 of it, then simply bent the cardboard over the top tank covering the radiator cap with 4 or 5-inches of cardboard...kinda acting like a upper fan guard. The hood actually will hold the folded cardboard in place and prevent the cardboard from slipping down and falling out onto the road.
--- When running cardboard in front of your radiator, remember that once you have your truck warmed up nicely, once you get to where you're going, do not idle the truck longer than a few (5?) minutes, or it will begin to overheat.
--- remove the headliner and cut a few sections of 1" Styrofoam beadboard that will fit/pinch between the roof rails. This added insulation will hold in some of the heat & will also make it a tad quieter inside. It may also help keep out some of the summer heat as well!
It worked for me! :thumright: :cheers: :steering:
BarnieTrk
-- '63 F-100, 2WD, 223", T-18 4spd; owned '74-'76
-- '65 F-250, 2WD, 240", 3spd; owned '76-'79
-- '94 Ranger XLT, 4-cyl, 5-spd; owned '97-'14, put on 309K miles. Sold it running.
-- '65 F-100, 2WD, 390", T-18 4spd; owned since '81. Still licensed & driven by me.
-- '65 F-250, 2WD, 390", 4spd/OD; owned since '08. Still licensed & driven by me.
-- '06 Ranger XLT, 4-cyl, 5-spd; owned since '13. Licensed and driven by me.
