A little disapointed after the alignment
64 f100
Re: A little disapointed after the alignment
Post by 64 f100 »
Paul, skill sets is the operative word here. Personally, I would replace the whole axle and see if that corrects the problem, before messing with bending one. If, I did not have access to a good front end shop that is. This is because I have many used ones available. Those of you that like to drop your trucks down low are asking for a serious set of problems, in my opinion. I personally like the looks but feel that it ruins the truck for anything that it was designed for. It is no longer a truck. Of course you most likely are not going to haul anything heavier than a picnic basket. I like to set up high with a good range of fire.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Rich, I agree! Usually if the camber is off severely at stock height, there is another problem. Not knowing the history of the beams, it is hard to determine if they have been bent to suit the previous application.
