Classic performance power steering
Well finally got around to installing my new 5000 series ccp power steering box and got rid my Toyota box All I can say is that the ccp box fits great and works like it should the only problem I had is the ford steering pump didn't have enough power to make it work so we went to a Saginaw pump and everything works great .IF you want power with your straight axle AND you wanna keep your 3 speed on the column this will bolt right in mount with three holes just need a universal joint to hook it all up and your done!! if you want more info pm me please
1234 sps
