The Lokar shifter will be coming out this week
Braved the rain and got the C-6 shift arm from the local U pull yard along with a kickdown rod I will try to make work,I am going to make a couple spacers to fit the 69 column to my 66 instead of welding on a 66 bracket so I hope by the end of the week I will have a column mounted shifter in the truck and then start looking for a under dash a/c system to install. I also ordered some parts from Jegs to hook the kickdown rod to the edelbrock carb.
Re: The Lokar shifter will be coming out this week
Its about done,all I need to do now is pull the pan and replace the arm and refill. I am waiting on a factory deep pan off a 4x4 then it can go togather and road test time.
