front wheel size
shocker998md
front wheel size
Post by shocker998md »
im not sure what size wheel I should go with on my 66f100. It has a coil and a half cut out of the front and a 215/55/15 tire. Im looking at the Cragar 15x7 or 15x6 wheel and im wanting to run the 7 wide in the front. Heres the link to the wheels.im just worried about backspacing and width. I do have power steering so Im not worried about that.
http://www.jegs.com/i/Cragar/260/313-57 ... tId=752139
http://www.jegs.com/i/Cragar/260/313-56 ... tId=752139
MeZapU
Re: front wheel size
Post by MeZapU »
I have 15x8's on the front with 235/60/15's. Pushes it right out to the edge. No rubbing. Painted hammer tone silver with trim rings.
http://www.summitracing.com/parts/crr-3105855/overview/
Black 1985 GT
Yellow 1973 Mustang Mach 1
Black 2012 5.0 GT, 6-speed, Brembo brakes, 3.73's
Wimbledon White 1966 F-100 Shortbed, Styleside, 390, Tremec 3550, Fitech EFI
William-in-St George
MeZapU! Beauty truck. Shocker998md, I use 7 inch smoothies on my white truck. They work well but with fat tires you will need power steering. I used some late Bronco 7 inch wheels on the red truck that are very similiar to the ones MeZapU has on his truck. Again power steering on both trucks. IMHO!
William-in-St. George
F164
Post by F164 »
I would go with 6 on the front and 7 on the rear to even out the track width some.
shocker998md
I already have 10s and 275/60s for the back. I think ill go with the 7s or maybe 8s. Im not sure now. I think the 215s may not fit an 8" wheel.
shocker998md
bump anyone have some more thoughts between those 6s 7s or 8s? Truck is lowered slightly in the front. I will be running 10s in the back.
BlueGhost
Post by BlueGhost »
I run 235/70's up front on 7 inch wide wheels and 275/60 on the rear on 8 inch wide wheels. I like it because the tires are all the same diameter.
6083
6084
SBC is a defunct phone company, not an engine option.
shocker998md
Are you lowered in the front? That's my delema is figuring out what width and backspace and tire size up front.
BlueGhost
Post by BlueGhost »
Mine isn't lowered, well except for what 50 years has done to the front springs. I'd say go with a 7 inch wheel and whatever height tire you need to keep from rubbing.
