Was carpet a option in 66
66camperspecial
Post by 66camperspecial »
The floor mat did not survive being removed this time and would like to find another but also thinking about carpet if cheaper,my 66 did not have sill plates and if I do go with carpet I will have to find some that will work so could carpet be ordered and were there sill plates made.
64 f100
Re: Was carpet a option in 66
Post by 64 f100 »
I don't know if it was an option, but it was installed in the Rangers and even had a cover for the tank, as the tank would show because of the bucket seats. that being said, options were more available in those days as special orders than today. One word of caution about carpet in these trucks. Our trucks are prone to leak and carpet holds water. In addition, the sealant used to seal the windshield is not common toady although available from 3M and available from my PPG paint source but not always used as it should be allowing the windshield to leak. Also, the roof drip rail sealing Is often neglected and allows water to leak there also.
66camperspecial
I will most likely stay with a rubber mat since it will be making trips to junkyards to get parts,I did find some sill plates but at a hundred dollars a pair I will forget about them for now.
SLICKCOLLECTOR
Post by SLICKCOLLECTOR »
66camperspecial wrote:The floor mat did not survive being removed this time and would like to find another but also thinking about carpet if cheaper,my 66 did not have sill plates and if I do go with carpet I will have to find some that will work so could carpet be ordered and were there sill plates made.
I was pleasantly surprised that the carpets manufactured by ACC for our trucks now, and sold by LMC actually fit. the carpets were short on the kickpanels on each side by an inch or 2 and left a big gap. very very disturbing. now the carpets are 2 or 3 inches too wide and you cut to fit. takes a little more time but you can cover your whole floor. I guess so many people bitched the manufacturer changed the pattern. this went on for a few years. but I would now recommend the LMC carpet. I just installed one last week. it ain;t perfect with some puckers and such but it is cheaper than a custom made carpet at an upholstery shop.
jim
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
69supercj
Post by 69supercj »
I've got a spare set of used sill plates that I would let go if your interested.
66camperspecial
I found a pair at the local old junkyard today on a 66 custom cab and was able to save all the original screws too,got them for 10 dollars and heading out to the garage to clean them up.
