!962 F100 Door seals
bbrix
Post by bbrix »
Is there a recommended supplier of 1961-1966 F100 Door seals? The last set I bought were too thick and wouldn't allow the doors to close properly. Thanks for the help.
Hunter's 64
Re: !962 F100 Door seals
Post by Hunter's 64 »
http://dennis-carpenter.com/door-seals/ ... 120530-PR/
These guys are known for their ford rubber goods :2cents:
Danny
been there done that with the bad rubbers
http://www.flashbackf100s.com
also check out the hints and tricks section, theres some good posts on installing all the various rubbers and other door pieces
Carpenter is the right source, there is at least one other manufacturer source, but I would highly recommend buying the Carpenter versions from Tom at Flashback F100. He supports us and is an active member of this forum, (6166 Junkyard Dog) and as such deserves our support IMO. He is very knowledgeable of the slicks (you become that when you buy as many as he does regularly) and just good people to deal with.
Paul.
