64 the adventure begins
64 litl un
Post by 64 litl un »
The 64 has been moved out of it's last resting place and now it's staging in the front yard awaiting a trip to the my parents barn. The barn has been the building area for Brown brother's projects since we were kids.....so this is big, at least for the 64. This time it's going to be my son and I.
I did another quick inspection to the truck and I have some good news!!! The cab mounts are in great shape! :D Unfortunately, that's about it. :(
Really it's a good old truck and it has it where it counts but she is rough. Image
I'm going to take a simple approach, clean it up, fix or replace whats broken and make it as pretty as we can.
I have some simple questions. has anyone put a 240/300 in one of these earlier trucks. I have a 65-66 240 complete with transmission.
I know the big block crossmember can be used for these. Will the Z bar for a 65 work? Will the clutch/z bar mounting pivot ball match the 240 like it did the 223 as far as engine location?
Are there any replacement panels for the bottom rear of the flareside fenders? The fenders are solid up top but the bottoms behind the rear wheels are pretty much history. I hate to scrap em or bob em as that's the only area that needs repair. Have any of you rebuilt the rear fenders in that area?
LM14
Re: 64 the adventure begins
Post by LM14 »
Remember to do a build thread in the "Projects and Builds" section. We like pictures!
sgettin
Post by sgettin »
I don't think a repair panel is produced for the rear of the rear fender (there is a patch panel for the front). Also I remember seeing a repoped lower flat panel for the bed side infront of and behind the fenders but can't recall who produces it, I think it was for a short bed?. It may have been these guys: https://www.npdlink.com/store/catalog/B ... 860-1.html
And like Steve said make sure ya post up a build thread.
Good luck.
Following....and we do like pics. Good luck with your build.
unibody madness
Post by unibody madness »
Glad to see its back to being worked on. father son projects last forever in your hearts!
bobenhotep
Post by bobenhotep »
I put a 300 and a 3 speed in my 63. I used a crossmember for an FE engine and the engine mounts for an early 70s 300. I set the crossmember on 3 inch blocks so that the front pulley would not hit the crossmember. The trans crossmember is made out of channel. The z bar will work, but it will be at an angle. I have not had problems with it yet. I had to make a throttle linkage. That is about all I can think of right now.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
