Crown Vic swap without lowering as much?
I've been checking out tons of info on the Crown Vic front suspension swap and like everything about it but the amount of lowering. Is there a way to do this swap without going so low? Only thing I have found looks a little spooky to me. Don't mind going down a little, but I want my '64 short wide to still look like a truck. Sorry if this has been beat to death.
- unibody madness
Re: Crown Vic swap without lowering as much?
instead of aligning the crown vic crossmember with the bottom of the frame, align it with the top of the frame. Should give you a few more inches in ride height.
viewtopic.php?f=32&t=18944
So if I understand you correctly, the Crown Vic needs a spacer because it is wider than the existing frame. So putting the spacers at the bottom instead of the top should make some difference. Is that correct? If so, can anyone give me some idea of how much that will lower the truck. Seems like I could use a little body lift too if that is the case, but I really don't want it to look really unnatural. (Pretty sure that sounds ridiculous since I want to change the suspension, but please work with me here.)
I was thinking that I heard the easiest way to mount the VIC front end on the frame only lowered the truck 1-2 inches?
