Carb Question
Mr. Jones
Carb Question
Post by Mr. Jones »
Might need to replace my carb,wondering what some of you are using on your 240/300.I have a Holly/motorcraft 1940 one barrel.Also what type did Ford use 66 and up.
Thanks,
bobenhotep
Re: Carb Question
Post by bobenhotep »
I have a Carter YF on mine. I think the YF was the standard carb on all of them later on. If you don't have a load o matic setup it is a good one, because it is easy to rebuild and has good fuel metering capability. It is also good if you want to get rid of load o matic, but you will need to change the distributor also.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
Re: Carb Question
I have a mid80s 300 with Offenhauser dual plane intake and 500 CFM Edelbrock. Carb is overkill but I could not get the smaller Holley to stop throwing extra fuel.
Re: Carb Question
i ran a clifford and headers with a 2v holley on an otherwise stock 66 300
worked very well and i would do it again.
Mr. Jones
Re: Carb Question
Post by Mr. Jones »
Engine has a stock intake and vacuum advance type dist....
