Water pump pulley interchangeability???
Will a 223 water pump pulley interchange with others? I'd like to run a double belt pulley but currently have a single. I see lots of double belts for small blocks online. Wondering if the bolt spacing is the same. Thanks.
Re: Water pump pulley interchangeability???
if i recall correctly its a fairly small diameter pulley on the 223 water pump
i do know theres doubles for the 300 6 cyl, not sure of fitment but someone with a 300 might be able to answer that
also as a lot of 223s were in bigger trucks like f500 600 etc you might look at those 223s for the 2 pulley setups
http://www.mustangtek.com/pulley/Pulley.html
Save that to your favorites. It has a ton of useful information.
