Powdercoaters in OKC area?
I've had wheels, brackets, and headers coated by a couple of different shops but its been years ago. Who have you used and were you pleased with quality and pricing?
Re: Powdercoaters in OKC area?
So does nobody use a powdercoating vendor or are you doing it yourself?
I use some powdercoat but he's too far from you to do you any good. Talk to some local racers and see who they use.
Might want to find a local guy call them and ask if you can come by and see some of their work, if they dont want to do that ,find one that will .... if they do good work they will be more than happy to show it to you. also if they are real busy thats usualy a good sign also, most of the time. Steve's way works also
Danny
Danny
LM14 wrote:I use some powdercoat but he's too far from you to do you any good. Talk to some local racers and see who they use.
I am thinking about buying a set of old headers from TruckRat and trying my hand at it. Buy the gun and powder from harbor freight and I can get a used oven from my bro-in-law and bake them.
Hunter's 64 wrote:Might want to find a local guy call them and ask if you can come by and see some of their work, if they dont want to do that ,find one that will .... if they do good work they will be more than happy to show it to you. also if they are real busy thats usualy a good sign also, most of the time. Steve's way works also
Danny
Another good idea. Thanks!
The powder coating companies I deal with (3 different one) will not do headers. They will do cast iron manifolds but not tube headers. They expand and contract too much and the coating will lift, crack and the tubes will rust. There is a high heat coating but it is actually meant for exhaust pipes or cast manifolds, not headers. The actual coating used for headers is ceramic and works with the expansion/contraction, it's totally different stuff.
One of the powder coaters I work with actually told me if a powder coating company says they can use normal or high heat powder on headers to walk away. It has to be the ceramic to work long term. Some show cars can get away with it since they don't run that long but if you plan to actually drive the engine, get the right stuff.
There is an exhaust coating you can brush on after media blasting
that you can try. Pretty sure Eastwood has it. Looks like cast iron when dry. TR
Truckrat wrote:There is an exhaust coating you can brush on after media blasting
I have to decide on which headers I want to go with. It appears that to get a decent set you are looking at $500. That's probably going to wait a while.
Buy your new headers already coated. It's a lot cheaper in the long run and you usually get a better job. I know Sandersons come both ways, I got uncoated because I'm not doing a stock install and was afraid I would have to modify them. I would have gotten coated if it was a pure bolt-in deal.
