Headlight problem
Casey 65
Headlight problem
Post by Casey 65 »
I discovered my headlights don't come on, (high and low beams). everything else works, turn signals, parking lights...
Can't find a problem with the wiring, good ground, all connections tight... Any suggestions?
Re: Headlight problem
Switch gave up, or, most likely the circuit breaker integrated with the switch. Sounds like an opportune time to do the relay upgrade, might even help insure the replacement switch will live, ah, half a century!
Test for power to dimmer , if no power replace headlamp switch, if power is at dimmer input, replace dimmer switch.
Casey 65
Post by Casey 65 »
Thank you Paul!
