391 Exhaust??
Mr. Jones
391 Exhaust??
Post by Mr. Jones »
Found a set of 8 bolt,centre dump exhaust manifolds still on the engine.Will these bolt on a 352 head.
Thanks,
Re: 391 Exhaust??
no
look at the pics and see why, the extra bolts and extra holes
330\361\391 FT
FE, 352,360,390 etc.
now if you found a set of these cast iron header that would be worthwhile
these are also useable
Mr. Jones
Re: 391 Exhaust??
Post by Mr. Jones »
Brian,
Thanks for the quick response,I was actually at the junkyard debating to pull or not pull'em.Ended up getting a set of rust free 64style inter- fenders instead.
Thanks again.. See you in Salina
tomrooster
Re: 391 Exhaust??
Post by tomrooster »
Dan, they will bolt up but they have an extra hole in the middle for a heat source to carb. I think I read somewhere that there is a clearance issue on something, maybe the steering box. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
chris401
Re: 391 Exhaust??
Post by chris401 »
I mocked them up on passenger side but not the driver. Thanks for the tip. I have a 2wd 65 F250. Moving the perch to the I6 location and extinding the engine mounts forward on a plate they will clear the pipe. As far as the extra hole that wont seal I am putting a 3/16 plate between head and manifold. I will mock it up on the driver side before going any further. I am keeping manual steering so maybe the manifold won't hit box.
Re: 391 Exhaust??
yesterday when i was looking for those pics i ran across this
pretty old but might be of some help
seems you may already have figured around a few of the issues
http://www.ford-trucks.com/forums/11730 ... heads.html
chris401
Re: 391 Exhaust??
Post by chris401 »
It is close on the passenger side crossmember, about 1/4" over it. Being a 2" pipe I think the exhaust man can clear the member with the 5" he had to play with. If not I'll make a 45° adapter between pipe and manifold out of some thick 2 1/4" pipe. I had thought of welding up the hole but if it cracks or won't work I'll have a chunk like Rusty Old F250 in the article.
