The inner bore is going to need to be quite small in order to accommodate the 5x100 pattern so that might be something to consider in terms of clearance.
^Agreed, this is something I'd suggest you look into further, particularly if you're going to go with the CV front suspension. I'd do some digging to see what size of wheel you can get away with, and what tire size you'll need to run in order to make it work. I know the CV does limit your wheel choices, although given the list of vehicles that use the 5x100 lug pattern I wouldn't be surprised if your wheels have a high offset intended for a FWD application.Hunter's 64 wrote:with a 8.5 wide wheel I hope you have a large offset or a thin adpt or you might rub inner fenders
Danny
