66 Parking light housings
Does anyone know if there is suppose to be a gasket between the parking light housing and what in bolts to or is it just metal to metal? Thanks for any help.
- ThinLizzy13
Re: 66 Parking light housings
I do believe they came with gaskets in them. The few trucks I've removed them from had ratty old gaskets that were barely there...
The trucks I've worked on were metal to metal but the amber lens to housing had remnants of a rubber type seal to keep the bulb clean and dry.
- Roger Carter
4 Baja wrote:The trucks I've worked on were metal to metal but the amber lens to housing had remnants of a rubber type seal to keep the bulb clean and dry.
X2.
And some of the ones I have had appeared awful original. A look through the Illustration section of the parts book should answer the question definitively.
Roger Carter
Mine was metal to metal when i got it.
- 6166 Junkyard Dog
Just a reminder that 65 and 66 park light buckets are different,,,,,,, Quick anybody know
Now Cooper will try his best
That is a new one on me! Are there two service replacement parts also? I know there are two different applications, not aware they varied year to year. Does it have to do with the bulb socket?
- 6166 Junkyard Dog
Paul you see the 65 bucket has a ground wire attached , then goes to a ground position usually on core support and the 66 has one stud that's used as the ground with no extra wire
Thank you everyone for your help.
