k20 front clip
TheTurtleKing
k20 front clip
Post by TheTurtleKing »
I know a lot of you guys use crown vic and Dakota front clips on your f100s but I would really like to keep the 8 lug bolt pattern on my 63 f250. I have a 73 k20 rusting in my parents back yard and was wondering if I could rob the suspension off of it. Has anyone done this? thanks.
jeepbut
Re: k20 front clip
Post by jeepbut »
K20 would be a four wheel drive. Are you converting to 4x4?
TheTurtleKing
Re: k20 front clip
The one I have is 2wd
FarmMotorSports
Re: k20 front clip
Post by FarmMotorSports »
Is the C20 disk front? (73 should be disk...)
Is the front suspension in good working order?
If it needs tie rods, ball joints, a new steering box, brake work, etc. I don't see the advantage...
It's your truck, most here wouldn't like the off brand front end. Only thing I see is your running in uncharted territory.(not a popular conversion)
The C20 front has a different size for hub centering. Keep that in mind when selecting wheels...
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
Re: k20 front clip
As Jeepbut stated, K20 designates 4wd, and on a '73, may well be full-time. If it is converted to 2wd, it would largely depend on the conversion. If it is in fact C20 components, next question is, coil spring or torsion bar? If 2wd, it is also likely to have a front mounted steering box, which may add further complications doing a clip.
TheTurtleKing
Re: k20 front clip
I guess, it's actually a c20 then. I believe it is coil spring and I don't know about the steering box. I'll call my dad this afternoon and have him check.
Anthony
Re: k20 front clip
Post by Anthony »
My boy Zak has a 63 uni with a late 70's c10 front clip grafted in... it gives him the ability to bag it and it slid inside the slick frame.. i dont know if the 20's will do the same though..
TheTurtleKing
Re: k20 front clip
Anthony wrote:My boy Zak has a 63 uni with a late 70's c10 front clip grafted in... it gives him the ability to bag it and it slid inside the slick frame.. i dont know if the 20's will do the same though..
Interesting , is there any way you could put me in contact with Zak or post a link to a build thread? I'd like to pick his brain.
Re: k20 front clip
Just make certain that the frame rails are solid where the steering box mounts, and that you run a sturdy front bumper/ additional crossmember to tie the frame rails together.
TheTurtleKing
Re: k20 front clip
For anyone else looking to do this conversion, my 73 c20 frame is 4" narrower than my 63 f250 frame so I'm my case it isn't going to work.
LM14
Re: k20 front clip
Post by LM14 »
If it's 4" narrower, then you are looking at the frame sliding inside the F250 frame like Anthony talked about on Zak's truck. 2" on each side would be about the width of the F250 frame. No idea how you would come out height-wise.
