Dash lights / Bulb covers
"Whitey Ford"
Post by "Whitey Ford" »
So Im redoing my dash and all but the indicator light cover? or whatever is in front of the buld in the little circles are gone. I had plastic bag taped over it and it worked well but what is everyone else using? Its for the indicators and 'lights on' indicator. the 3 holes in the speedometer gauge. Hope that makes sense.
Girls love a pick-up man.
bobenhotep
Re: Dash lights / Bulb covers
Post by bobenhotep »
I used bulbs like the "turn signal indicator fix" link in my signature.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"Whitey Ford"
ok thats cool. i was wondering if it would melt on the bulb but guess everything turned out well.
bobenhotep
I have not melted one yet. I have not tried it on the high beam indicator. Just the turn signals. I should do an overnight test on one to see if it melts.
"The Iron Rhino"
-duraspark II/ HEI
I've always thought the plastic colored tabs from a three ring binder organizer kit could be cut to provide new lenses. I haven't tried this, but it seems like an easy cheap source.
Lowell
Post by Lowell »
Maybe a plastic seven up bottle?
bird55
Post by bird55 »
Yep this or Mountain Dew bottle.
There was a post on it somewhere in the past.
69supercj
Post by 69supercj »
I used a 7 up bottle and it worked fine.
theastronaut
Post by theastronaut »
Hobby Lobby or Michael's has translucent colored plastic sheets. Can stack them to make them darker, and wetsand the top layer with 2500 grit sandpaper to mimick the factory sheen.
