seat belts in slick crew
how do you get the anchor point in between the doors with out cutting a major hole.or cutting the welds
1966 crewcab
- Alan Mclennan
Re: seat belts in slick crew
Have you got a photo we could look at 65 ?
- FarmMotorSports
Can it be lowered from the headliner area in to position?
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
That is closed in solid on the top can come in above the head liner in the back seat. was not wanting to drill out the pop rivets. But might be only way
the wall between the doors http://s1175.photobucket.com/user/65cre ... r.jpg.html
http://s1175.photobucket.com/user/65cre ... a.jpg.html
_
http://s1175.photobucket.com/user/65cre ... 4.jpg.html
could not get to post pics but could links
_
1966 crewcab
- Alan Mclennan
Thanks Allen. It is welded on the back side of the panel. I would be happy with just a lap belt but wife wants shoulder belts.
1966 crewcab
- PFM-64f100
This is how I did mine. Drilled a hole in the flat plate then welded a nut onto the back of it. Then I used some pop rivets to hold it on there. Not the best but figured it would slow me down for now.
I do have plans on redoing it by making a horizontal cut in the middle (location behind the current plate) then sliding the plate inside then reattaching the plate with the current pop rivets holes. This way it will be pulling on the complete panel and not just the rivets.
Wish I had more photos but looks like they got lost with the HD crash a while back. Dang HDs.
Thanks for the reply and pics PFM. Was thinking of drilling the rivets out to gain access. Then putting them back in then adding a weld between each rivet.
1966 crewcab
Where did you source the seat belts?PFM-64f100 wrote:This is how I did mine. Drilled a hole in the flat plate then welded a nut onto the back of it. Then I used some pop rivets to hold it on there. Not the best but figured it would slow me down for now.
- PFM-64f100
Some place in Oklahoma I think. seat belts plus maybe. It has been a number of years sorry.orangeRcode wrote:Where did you source the seat belts?PFM-64f100 wrote:This is how I did mine. Drilled a hole in the flat plate then welded a nut onto the back of it. Then I used some pop rivets to hold it on there. Not the best but figured it would slow me down for now.
