Added Hood Ground Cable
chris401
Post by chris401 »
Was on my truck when I bought it. No signs of any past hood marker lights. Anyone else have one and know if it was a Ford campaign or not?
Re: Added Hood Ground Cable
never saw one before on a slick
longcabjohn
Post by longcabjohn »
All I can remember on slick is a little spring like strip on top of cowl, near end of rubber strip on right side. Some gm used a little braided strap. The reason for grounding hood was to remove static from radio with the old am signals.
Johnny
chris401
Post by chris401 »
64 f100
Post by 64 f100 »
One comment on that grounding strap. The bolt on the hood had to be there to start with, as I se no way you could put one into the inside. I see no way that could have been installed after the hood was welded together. .
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
jefflovesf250s
Post by jefflovesf250s »
All: does this help reduce static in radio? Speculation by an electrical engineer friend.
Any thoughts/experience?
Jeff
Lowell
Post by Lowell »
I believe Johnny is right ,the hood was grounded to shield ignition noise from the antenna, you might not always get a good ground through the hinges. That bolt could have been inserted into the hole with a small wire, i have seen a lot of grounding done on vehicles with Ham, cb or other types of two way equipment on board. I have heard that a lot of new vehicles with computers can really be a problem to communication recievers, although my 02 Ford f150 is pretty quiet.
Roger Carter
Post by Roger Carter »
For what it's worth, my '78 F-250 has a factory installed ground strap, cowl to hood.
Roger Carter
chris401
Post by chris401 »
I have heard solid copper spark plug wires will cause radio interference. Would a hood ground cable help that scenario?
Lowell
Post by Lowell »
chris401 wrote:I have heard solid copper spark plug wires will cause radio interference. Would a hood ground cable help that scenario?
It would be worth a try, but you may have to replace the plug wires to really eliminate the radio noise.
chris401
Post by chris401 »
Hood pictured is my F-250. Not working on the F-100 yet but I have acquired some 65 vintage parts for the project. No copper cables but I have been picking the memories of those in that era. The FE was taking off but the aftermarket parts for trucks were slim to none.
