Need help in iowa
Need help in iowa
What's up fellows? In currently working in sioux city, Iowa and I bought my first slick. Found it in a barn where it'sit's been sitting for 18 years. In working 7 days a week and can't do any work to it so I found a local guy to do it for me. Well to save to I spent a lot of money and it's still not running right. The motor is it excellent shape. I replaced everything coil,distrib.,wires,etc etc. He said he was done. So I drove her to the gas station to fill up and evening was fine. So by this time in happy and feeling good. So I decided to go cruising. About 30 minutes into my extacy filled ride it stops shifting.(3on the tree).it's stuck in one gear. So there went my excitement. So I had to drive home doing 25 while people blowing horns and sticking fingers. I popped the hood and where the rooms connect the transmission to the steering wheel is good. I can move it and feel it going into gear. I think it's something in the steering wheel. Can anyone tell me what it is?
Re: Need help in iowa
Probably worn bushings in the shifter rods... (Not a terrible thing)
I'm a 4 spd guy... So others will tell you more
By the way
From K A N S A S
By the way
From K A N S A S
If bringing both levers at the bottom of the column to the neutral position doesn't allow it to be shifted from the column lever, the problem is likely in the column. The first/ reverse lever itself may be damaged, or it may be a shift tube failure. There is a tacked on key on the shift tube at each end which may break away. At any rate, if all linkage works while moved manually at the column; disassembly is likely required.
Thanks. I'll check it out when I get home
What condition are your front cab mounts in? If the fender to door gap gets bigger at the bottom, this is usually a sign that the cab mounts are soft, and as the cab drops, it can bind up the shift linkage.
As others have mentioned, there are a number of causes, hard to diagnose from the written word, but will give you some ides of things to check:)
James
James
