when the p.o. doesn't think things through...
this how much clearance i have with the motor jacked up.
oil change time...2.5 hours and four beers. lol
66/460 oil change
- ezernut9mm
66/460 oil change
Re: 66/460 oil change
Can't see where your drain plug is Chris? Is it just
above the cross member at the side or left front corner,
or on the bottom? Can't tell in the picture. TR
- ezernut9mm
towards the back of the sump on the passenger side. when the motor is all bolted in you cannot physically remove the plug from the pan.
Don't know if this would solve your problem,
but do you think it would be possible to make a hole
in the crossmember big enough to access the drain
plug with a socket and extension? I realize the I-beam
axle is right below there. Not sure of the room it would
make if any. Wondering if any other pans for 460s are
made with a different drain in them. That is a definite
bummer having to do it that way. TR
I have a 400 in a 63 with a similar problem. I went to the parts store picked up a couple of brass nipples, a 90, a "cap" for one end and a length of tranny cooler hose to fit the nipples . Put the 90 and one nipple into the drain plug, connected the hose to the other end with the cap. No more clearance problems.
Jim
63 F100 Long bed 351M/C6
64 F100 Long bed
78 F250 4X4
95 F350 4Door Dually
03 Expedition
64 F100 Long bed
78 F250 4X4
03 Expedition
- 6166 Junkyard Dog
Chris I believe the trouble is you need a truck oil pan,,, Tom
Now Cooper will try his best
Tom is right. Mine has all 79 truck running gear with no problem.
Johnny
Johnny
- PFM-64f100
my 64 with 460 has the dak front end and I had to put a truck rear sump pan in it. 4X4 (80's ish and up till 92 should have them). It is a pain but might be worth the extra effort.
I just think you need more beer!!!
