Slick 1 Ton To Dodge Wheels
chris401
Post by chris401 »
I am going to look at a 1973 Dodge 12,000 gvw motor home Friday. I remember these wheels fit old Fords. What are the measurements needed to fit a Ford axle?
Re: Slick 1 Ton To Dodge Wheels
My '64 has 5 x 5 1/2" bolt pattern....the newer Dodge Ram trucks have the same bolt pattern. I had a '55 Dodge 1/2 ton that had 5 x 4 1/2 bolt pattern. I have seen the 17" and 20" (I believe) Dodge wheels installed on the mid 60's Ford trucks with lower profile tires. Everyone has an opinion on that....so I'll leave that part of it alone. Your '65 Ford truck should have 5 x 5 1/2 bolt pattern....then I looked again and saw that your truck is a one ton....so I dunno...
chris401
Post by chris401 »
My F-250 is set on the wheels. I was thinking about the larger truck owners wanting to get one piece rims. I knew a couple of guys who mentioned the Dodge wheels. Both gone so I am hoping someone here knows.
jamesdfo
Post by jamesdfo »
Subject line in header of OP's post was Slick 1 Ton.....but just so all the bases are covered:
Slicks:
F100 = 5 bolt, 5.5" BC
F250 = 8 bolt, 6.5" BC
F350 = 6 Bolt, 7.25" BC
chris401
Post by chris401 »
jamesdfo wrote:Subject line in header of OP's post was Slick 1 Ton.....but just so all the bases are covered:
Slicks:
Easy to find now, thanks for posting all in one. Was it F-550 that the lug pattern got bigger?
I think some of the 60s , IHC pickups had that pattern too
And also the army jeep m715 wheels were the big 6 pattern
Yep, F500 up used a yet bigger pattern. LMK if interesting in selling the Dodge wheels.
chris401
Post by chris401 »
Toyz wrote:Yep, F500 up used a yet bigger pattern. LMK if interesting in selling the Dodge wheels.
Let
Me
Know
Took a second read.
