The interior on my 65 has some creative work done to the dash knobs. I'm not sure what the previous owner used, but it looks like they inverted the white inserts and then painted them green to match the truck. My plan is to swap them out for the original style as I find the knobs on parts trucks.
I have a cigar lighter element but there is NO Bezel with it. I have been looking for a while, but I can't find an original element with the bezel. I'm not dead set on it being original, and I have seen reproduction units, but I thought I read somewhere the bezel on the repros is not the same diameter as the originals, its a little smaller, and then it would stand out when in place and be noticeable. If they are the same as originals, I will get a repro unit.
Can anyone confirm that about the reproduction units?
Thanks, Bradshaw
Cigar Lighter Original vs Repro
Re: Cigar Lighter Original vs Repro
I will look at my 65 tomorrow and let you know about the size of the bezel. All the knobs are repopped. It is getting hard to find good knobs on parts trucks anymore.
Michelle
I checked it out this morning and my bezel is the same size as the other dash bezels. My bezel is an original but I installed a new knob that I bought from one of the vendors.
Michelle
Thanks Michelle, I will get out the calipers and measure one my other bezels and I will know the diameter, the check with some of the suppliers for the repro units and see what they measure.
I was able to locate an original lighter at a salvage yard 3 hours away last week. Called up and the fellow there pulled it and mailed it to me. It was delivered today. Needs cleaning on the outside and an insert. Put the dial calipers on it, the bezel measures 1.3" and a few ten thousandths. NPD catalog is where I saw the repro with a bezel diameter of 1-1/8. So its a little more than an eighth of an inch difference. Im not sure it wojld be noticeable but the I'm thankful i was able to find an original.
Good deal, I am glad you found an original one.9Fingers wrote:I was able to locate an original lighter at a salvage yard 3 hours away last week. Called up and the fellow there pulled it and mailed it to me. It was delivered today. Needs cleaning on the outside and an insert. Put the dial calipers on it, the bezel measures 1.3" and a few ten thousandths. NPD catalog is where I saw the repro with a bezel diameter of 1-1/8. So its a little more than an eighth of an inch difference. Im not sure it wojld be noticeable but the I'm thankful i was able to find an original.
Michelle
