Scott Drake pedal pivot bearing conversion
Anyone used the kit from Scott Drake that converts the pressed in bushings on the pedal bracket to needle bearings? I have mine apart and wondered if it's worth the conversion.
I'm thinking of this one sinice my shaft is ok:
[url]https://www.summitracing.com/search/bra ... w=SKU&ar=1
Thanx.
Thanx.
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Re: Scott Drake pedal pivot bearing conversion
Mustang Steve has had selling that set up for years. I think he is the one that first set it up and used it.
Michelle
Yup, I put one of these conversion kits into my '65 Mustang quite a few years ago and have been really happy with it.
After "sawing" nearly through the old bushings and pivot shaft from many years of use/abuse, the conversion sure made both the brake and clutch pedals work better than new.
Steve F
1965 Mustang Coupe
1966 F-100 Shortbed CC/Ranger
2010 Mustang GT Convertible
2010 Shelby GT500 Convertible
1965 Mustang Coupe
Wondering if the shaft length and diameter is the same for Mustangs and 1966 Slick. Might give them a call
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Called them and they said it wouldn't work. I'm sure someone here has made it work tho. Anyone?
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Did they specifically say why? That may give you the direction you need to proceed.slickstysix wrote:Called them and they said it wouldn't work. I'm sure someone here has made it work tho. Anyone?
No, they weren't any help. He just said "No, I'm 99% sure it won't fit anything but a Mustang. Several people have tried to put it in Cougars, Falcons and others without success." Sounded like a lazy a$$ response to me. I called back later for bearing dimensions and again he said "No, I don't have access to that information." Lazy....
I tried Summit who sells this and they said they don't have the info either. How hard can it be to grab a set of calipers and go out to the warehouse and check a few dimensions??
I did find this on Ebay:http://www.ebay.com/itm/252333877271?_t ... EBIDX%3AIT.
Contacted them and they said it would fit a standard 5/8" shaft. I might go this route even if it involves welding.
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Keep us updated Slick66!
- slixtyfive
Cool thanx Slixtyfive! I'll give it a try.
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
Anyone use this kit?
- Power brakes
- DJM drop beams
- Power brakes
- DJM drop beams
