Ok guys, I've done a lot of searching around on here and haven't come up with an answer for a 64 F100. Plenty of 65's, but not 64... I need motor mounts for my 64 F100 that had a 292 in it. I'm putting a 460 Lincoln in it and am striking out on mounts! Help please!
(Note: I got this 460/C6/driveshaft/shifter from a friend's running 64 F100 truck so I have everything I need besides the mounts)
73 Lincoln 460 in 64 F100. Need motor mounts
Re: 73 Lincoln 460 in 64 F100. Need motor mounts
You will either have to use the tubular crossmember style:
http://www.speedwaymotors.com/Big-Block ... ,1198.html
or the weld on ears with round cushions:
http://www.speedwaymotors.com/Garage-Sa ... 88122.html
or weld on mounts:
http://www.speedwaymotors.com/429-460-F ... ,7633.html
You will also probably need a tranny mount like this"
http://www.speedwaymotors.com/1953-64-F ... ,1174.html
No 429/460 stuff bolts directly into a 61-64 truck. You could also just buy a set of motor mounts at your local parts store and fab towers to fit.
or weld on mounts:
Thanks SPark! I finally have an answer! Much appreciated!
