352 motor mounts
352 motor mounts
I removed my motor mounts and didn't think to mark their orientation. I see that the threaded stud is offset relative to the vertical bolt holes that marry it to the block. So, should that stud be to the front or rear relative to the bolt holes? I had read on other sites of a "bump" that should be placed up but my mounts don't have a bump. Thanks!
David
65 F100 swb (352 3 spd manual, not running)
Previous rides:
69 Bronco, completed frame-off restoration
07 Kawasaki KLR650
92 Acura Integra GSR
65 Mustang 2+2 A-code
67 Mustang coupe C-code
Previous rides:
07 Kawasaki KLR650
Re: 352 motor mounts
Do you have a car 352 instead of a truck 352? I know the mounts are different, but I'm not sure what the car mounts look like.Mojave922 wrote:I removed my motor mounts and didn't think to mark their orientation. I see that the threaded stud is offset relative to the vertical bolt holes that marry it to the block. So, should that stud be to the front or rear relative to the bolt holes? I had read on other sites of a "bump" that should be placed up but my mounts don't have a bump. Thanks!
Not sure if you can make it out, but here's my truck 390 and you can kinda see the bump above the bolt.
Regards,
Corey
1966 F250 LWB
That's a big help. Thanks Corey. I can see the tab toward the rear and the stud forward of the bolts. The mounts that came with my 352 look like yours except without the bump.
Nice looking 390 you have going together. Is that a current pic or is yours running now? Are you running headers and an edelbrock intake? How do you like the combo? I broke a cast iron manifold tonight so that kind of made my decision for me about getting headers.
Thanks,
David
Thanks,
David
David
Previous rides:
07 Kawasaki KLR650
Previous rides:
07 Kawasaki KLR650
This is a fairly recent picture of my 390. I'm using a Holley street dominator intake, mild comp cam and headers. I'm looking forward to getting it in my truck and seeing the difference between it and my previously stock 352. I may swap my 4.10 Dana 60 rear end with a Dana 61 with 3.08 gears to help with highway rpms.
Corey
Corey
1966 F250 LWB
58-64 blocks only had the small unused motor mount bosses in Cory's photo. 1965 and up had all four. There are a few truck owners running early blocks and 1/4" - 3/16" steel plates with truck mounts on them. Years ago I slid my 64 engine forward and used 63 427 mounts. Had a couple of driveshafts made. Below is a simpler way to do it:
http://www.network54.com/Forum/74182/thread/1373027301
I do not belive there were any 62 blocks cast with alternator bosses. You will probably need to fab one to bolt to the generator bolt holes. One more thing on the early blocks. That foundry mount where automatic cooling lines useually bolt to goes all the way through the block. 58/59 did for sure.
some motor mounts are marked rh & lh. i'll try to post a pic. message is board attachment quota has been reached.
jim
jim
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
SLICKCOLLECTOR wrote:some motor mounts are marked rh & lh. i'll try to post a pic. message is board attachment quota has been reached.
jim
Good point, mine were marked.
1966 F250 LWB
Yep, 1/4" plate is what I'll try too. I'm relieved to know there's a fix. Was really worried I bought the farm with this engine.chris401 wrote:58-64 blocks only had the small unused motor mount bosses in Cory's photo. 1965 and up had all four. There are a few truck owners running early blocks and 1/4" - 3/16" steel plates with truck mounts on them. Years ago I slid my 64 engine forward and used 63 427 mounts. Had a couple of driveshafts made. Below is a simpler way to do it:
David
Previous rides:
07 Kawasaki KLR650
Previous rides:
07 Kawasaki KLR650
