alright more assembley questions 1966 ford
Maverick1965
Post by Maverick1965 »
1.ok antenna seal to cab? same deal as the wipers?
2.is using the fresh air doors in the kick panel important?
3. who do you guys and gals use for the headliner? would like to do a full wrap
4.the blinker i guess buckets in the front are they installed from the front or back ?
5. does anyone know the bolt size for the seats?
6.got my hood alighed good but when i close the back has to be pushed down? are the shot?
7..i would post pictures from photo-bucket but can't figure it out
thanks guys and gals your help is so appreciated
Michelle
Re: alright more assembley questions 1966 ford
Post by Michelle »
You can get the wiper seals from any of the vendors. Tom is a good one you can trust him.
Its not a must to use the fresh air vents, but it sure is nice in the summer.
Again you can get a new headliner.
I did my truck but don't remember now if they come out from the front or the rear, guess I could go look.
Not sure of bolt size for the seats, would have to look. But I would guess it is a 1/2 " or 9/16'
Try putting a couple of washers under the front where the hood to hinge bolts go. Don't ask me why it works but it does.
Click on the image you want to post, when it comes up click on the box to the right that has IMG on it. It should say copied when you do. Go back to forum that you want to post on and hit CTRL key and the V key at the same time. Then click on preview and if the picture is like you want it click on submit.
Michelle
Hunter's 64
Post by Hunter's 64 »
viewtopic.php?f=1&t=36148
Another member with a nice headliner option
Danny
64 f100
Post by 64 f100 »
Fiberglass is also available from Irl in Oklahoma.
AlsRyd66
Post by AlsRyd66 »
Question 4: Turn lamp buckets screw in from the front.
"Don't piss down my back and tell me it's raining" - Fletcher from The Outlaw Josie Wales
"We all go a little mad sometimes" - Norman Bates
This is a form seal with a lip around the edge.
They bring in a lot of air at your feet. Can get hot if you have not insulated the floor and firewall.
The are attached with screws from the front.
Springs might be weak. Hood can also be tweeked. You can use a plastic wedge (available as shims for construction) with the larger end towards the front between the hood and hinge to lower the back.
Hunter's 64
viewtopic.php?f=5&t=25049&p=224138&hili ... ge#p224138
hood fix #6, dont know where pictures went :dontknow:
Danny
