questian
- therealjoeshmoe
questian
anyone got some pics of what holds the front coil springs in on a 65 f100 2 wheel drive?
Re: questian
Joe: The bottom is held to the beam with a cup that goes inside the spring, the top sits into the pocket that is riveted to the frame rail, and has a small flat iron strap that bolts to the pocket to retain the spring.
See pics in post below
http://www.ford-trucks.com/forums/14403 ... lease.html
and this one has the exploded view from the Master Parts Catalog
http://www.ford-trucks.com/forums/14555 ... stion.html
James
James
- therealjoeshmoe
Re: questian
i have been driveing my truck for 20 years without the bottom and top holdcoil spring retainers on.. lol you can jack my truck up by the crossmember and the coils will just fall oout..
- slixtyfive
Re: questian
For what it's worth, my '65 didn't have the top retainer strap that are referenced above (or the holes that they would be bolted to in the spring cup/pocket). But it did have a steel strap bent like a hook that bolted to the I-beam and 'hooked' the frame crossmember. This prevented the I-beam from hanging down far enough for the spring to become un-compressed from the spring cup.
- Blackwaterforge
Re: questian
That's how my 65 was.slixtyfive wrote:For what it's worth, my '65 didn't have the top retainer strap that are referenced above (or the holes that they would be bolted to in the spring cup/pocket). But it did have a steel strap bent like a hook that bolted to the I-beam and 'hooked' the frame crossmember. This prevented the I-beam from hanging down far enough for the spring to become un-compressed from the spring cup.
My 66 has the spring retainers that bolt to the top
- therealjoeshmoe
Re: questian
so im putting dropped beams on my truck and there is nowhere to put the hook that hooks the frame on... will i be ok the just run no retainers>/?
Re: questian
Joe: Shouldn't be that hard to make the retainers out of a length of flat bar, even easier if you have a bench vise, or a press......
James
James
