T86 bearing retainer
I'm in the process of gathering parts to convert my car T86 OD to use in my unibody. I have found a NOS truck input shaft. But I'm coming up short trying to find the bearing retainer. Does anyone have one or can supply the part number for it. Thanks
Re: T86 bearing retainer
You may be able to use the bearing retainer off of a 3spd. They look to be the same. I have a y-block 3spd and could measure it for you if you do not have one. These are a little more plentiful.
Thanks. I can't believe how hard it is to find one. There seems to be an endless supply of the Ford 3 speeds but not so much of the T86's. One last question. The input shaft I found says it's for a 223. I found another for a yblock. What is the difference between the two?
