1965 4x4 transfer case shift knob
9Fingers
Post by 9Fingers »
Hello,
Does anyone have a photo of the correct shifter knob for the 65 4x4 transfer case?
I searched and could not find for sure what an original looks like. From what I have read, up to 66 had 2H, 4H, N, 4L, then in 66 the f100's had 2wd or 4wd no low range.
I have a later model np205 from a 78/79 but looking for more information about shifter knobs for 65, if shift pattern is the same, would like to use an original knob from 65.
Thanks in advance, Bradshaw
tomsrod
Re: 1965 4x4 transfer case shift knob
Post by tomsrod »
I can't seem to find a photo, but my avatar shows the two speed transfer case shift knob. The photo is from the 1966 Owner's Manual. The 1966 F100 4x4 was the only one that had the single speed.
Pat
9Fingers
Post by 9Fingers »
Thanks Pat for the diagram. Shift pattern is the same as what I've got.
I'll be on the lookout for one.
orangeRcode
Post by orangeRcode »
9Fingers wrote:Thanks Pat for the diagram. Shift pattern is the same as what I've got.
If you don't locate one, I know Steve Canup made one out of wood. Turned out great.
chris401
Post by chris401 »
9Fingers wrote:Hello,
If it turns out your 65 transfer case knob it unavailable but the shape of th 65 NP435 pictured that may be a start.
9Fingers
Post by 9Fingers »
orangeRcode and Chris401, thanks for the tips on wood turned knob or starting with the np435 to make a mod.
I have checked that popular online auction site and have seen a couple on there. May pick up one of those, one looks to need a good cleaning and some way of buffing down the finish, looks like its been in the weather a good while.
Bradshaw
