Clutch / Brake Peddle Interchange 64 to 65
claybreaker 144
Post by claybreaker 144 »
I am installing a late 90's clutch Mustang cable set-up in my 61 Uni and I saw a photo of a 65 clutch and brake peddle assemby and it looks like it might be slightly less work to install the cable quadrant on than my 61. Are the holes in the firewall and the dash the same from 61-65?
62 Unibody Short Bed Soon To Have CV Swap
62 T Bird
66 Elcamino
bruceandersson
Re: Clutch / Brake Peddle Interchange 64 to 65
Post by bruceandersson »
They are different at the connections at the steering column, not sure of the firewall connections.
orangeRcode
Post by orangeRcode »
Clay, are you going with a t-5 which is the reason for the mustang cable? I'm following because I would like to put a 5.0 and t-5 in my 65 roller. Be sure and post up any info you get and good luck on the project. :cheers:
