y block paint colors..ford red or old ford blue?
- aj64f100390-292
hey guys, I'm about a week or two out on my y block, and I've been throwing ford red or blue around for months, but its not like there's the best pictures of the blue on google...
Ya know on one hand most people don't have a red ford engine...but then again I don't see a lot of people painting a y block blue either..Ill post some pics tomorrow, I've painted up a valve cover with dupli color "old ford blue" 1621...I would gladly paint it to match the truck..but this is a backyard engine build..so Im looking for colors I can pick up quickly..haven't seen ford red at Oreilly's..they have it on the website though. just not sure what will look the best in my 64. but in the end this is just the daily worthy engine for it...not the final hi performance y block so if I don't like it I can always paint that engine another color.
Any ideas are appreciated guys...lets see those y blocks!
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now soon:pwr asst steering
Re: y block paint colors..ford red or old ford blue?
Between the two colors you chose, I like the red best for a Y block...But BLACK would be MY color choice.
- unibody madness
Paint it the color that you like best but they never came in blue. Here are some of my choices:
any auto store should have engine paint in a spray can, make sure you degrease it well, wipe it down with acetone last, and let it dry, heat the metal with sweating torch to rid of moisture before painting...you can see it weeping and drying so do not over heat metal, use a ceramic oaint on headers and intake.
viewtopic.php?f=32&t=18944
That grey w/red looks good. I've seen some yellow ones that are sharp as well. But in the end its your choice.
Can we take a sidetrack on this thread and also talk about paint that will retain the just painted look? These pics all look great, but how does the different engine paint hold up to the heat and abuse of being run? I don't think I've found that paint yet and have tried the sprays as well as some brush on.
I've always used red, but most of my y-blocks have been 55-57 which were not really red, but that's the paint you can find. They were originally an orange/red. Earlier ones were yellow, not sure about later ones.
I agree overall that it only needs to please the owner.
Anybody use por15 engine enamel. Mine is black with ford red valve covers. Thinking going with Ford red on the block with Mooneyes valve covers and my 1st generation blue Thunder intake.
- unibody madness
My paint held up pretty good except the intake exhaust cross over. There has been a lot of touch up,which is how I know to degrease,wipe down with acetone,and sweat the moisture out before painting. like I said,use ceramic high heat for manifolds but the 500* heat engine holds up for the block and tins, It does chip easily though.
Red is a difficult color irregardless of application, the original color of my engines was black with red tins but I went with the old ford grey w/red tins,and ford red w/black tins on my two y-blocks in order to spot oil leaks easier
I use Duplicolor with their primer underneath and their clearcoat over. Engine temp is intended to cure it all which sometimes makes it a little touchy installing. Have also shot Metallic gold undershot and then FORD red over. gives the red a nice subtle glow. However my 64 f-100 was issued black with red tin covers. It now has aluminum TBird VC's. and ram's horns.
Blue came on later ford passenger 292's and Fred Jones FORD factory rebuilt engines I believe. And of course other later engines used ford blue.
here's a couple examples of mine.
[youtube]https://youtu.be/ytvrQ-8fXcU[/youtube]
Sorry, can't figure out how to upload the video from photobucket!
Also wanted to say I painted this one satin Blaack. The latest version on you tube Is Gloss Black with clear. I like it better
And here is the TBird.
- skidoorulz
http://i746.photobucket.com/albums/xx10 ... 0_2426.jpg
Here is mine. It is Duplicolor Ford red and was bought at Oreilley auto. They stock it on the shelf. Originally it was all balack except the valve covers they were Ford Red
factory for the 61-64 y block and 6 was red covers with black block.
i do like the red/gray best as the gray makes spotting leaks easier and it just looks good imo
- aj64f100390-292
That engine posted above looks great, would have replyed ssoner, but ive heen in a grind on the 292 all week..its painted, and seeings as if I wanted to try somthing else later I went with old ford blue, as it was easy to get in my area, and I dont see to many doen in that color, also how long will the engine paint with ceramic last on a manifold...im lost on that, as dupli colirs is good up to 600°...and those get alot hotter than that..my father has used paint that said it was good up to 1600°..lasted a few months at most..dad thought about just reapplieing stove black polish on them every so often..I will post pics and a buold thread soon..
- aj64f100390-292
Ok more pics showed up they all look great...then again most engines when painted up right I supoose..but the nice thing is that as long as it stays sealed up and clean ,I could probably repaint it in a weekend if I change my mind..worst case senerio though..personally..old Ford blue is growing on me...I think with some chome or allumanum valve covers it will really pop, but that will all come in time though..but at the end of the day theres no shame in doing somthing different..well in some cases Inguess there could be
Would've took better pics if id remembered...had a week to work with with dad on vacation so..we took advantage of it as much as possible
