Cummins Conversion first crank
Blackwaterforge
Post by Blackwaterforge »
FarmMotorSports
Re: Cummins Conversion first crank
Post by FarmMotorSports »
Congrats you'll have yours on the road before I even fired mine up.
No mistake on what that is. A BT4 or BT6 ,muffler or straight pipe, the rattling top end will be heard long before it is seen.
Did you keep a stock manual transmission? Or upgrade to something bullet proof.
There is definitely a lot more room for the 4Cyl....
Will this one be at SlickStock?
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
Blackwaterforge
Thank You!
Cummins 4BT
Will be straight piped.
I am using the Borg Warner 4-speed that was in the step van.
I also have a Watson 3 speed auxiliary that I will be using.
36truck
Post by 36truck »
That's cool Nice looking build. Your truck so fits you & the work that you do.
Tom Williams
orangeRcode
Post by orangeRcode »
What kind of power do the 4BTs put out?
FarmMotorSports
Stock numbers range from 105 to 170 HP.
And 270 to 470 Ft lb torque.
And then there's turning them up! :twisted:
That can double those numbers, but kill longevity.
61 F250 Unibody
orangeRcode
Turn up the booooooost! :twisted:
Anthony
Post by Anthony »
that sounds AWESOME!!!!!
