1962 Unibody build
Re: 1962 Unibody build
My brother and I own and operate a small restoration and custom shop. We do most everything in house. I do all the mechanical, electrical and engine work, my brother runs the business. He used to do all the paint and body but back surgery has forced us to hire a body and paint man. We also have a metal fabricator who does some mechanical and interior as well. I'm also working on a 65' short bed for myself. I'll start another thread for it.
- IMG-20150727-00362.jpg (246.78 KiB) Viewed 2206 times
1965 F-100
1962 F-100 Unibody
1975 Chevy Vega drag car
1967 Mustang Coupe Vintage SCCA Race car
1962 F-100 Unibody
oh I'm looking forward to seeing this beauty.
I love the red.
I love the red.
- 390fastback
Looks sweet! What you going to do for wheels? ride height? and all that other good stuff??
plus many other's!
plus many other's!
Looking good, I really like that red. It looks like you started with a pretty solid truck. When you welded in the big back window did you weld the inside where the pinch welds were also? You don't seem to see too many cross draft paint booths any more, looks good. I'll be watching this build.
Watching....That is going to be a nice truck. More pics please....
We're planning on using steel rims painted body color with spider caps and trim rings along with white wall tires. I'm going to lower the rear with some DJM shackle mounts. I'm hoping to have the entire truck painted by spring.
- IMG-20150727-00363.jpg (244.46 KiB) Viewed 2189 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
We've bought and assembled the paint booth about three years ago. Down drafts are so expensive, it's all we could afford. I've still got lot's of welding to finish up on with the cab. I'm going to fill all the external seams on the cab and the bed caps in the rear at some point. Power is coming froim a 67' Mustang. it's a 289 bored .030 with a mild camshaft, K code heads, ceramic headers, holley 600, Weiand intake along with a C4 transmission. The 3:70 gears will be changed out for a 3:00 or a 3:25. Will have air conditioning and heat from Classic Air. Hope to have more pics later next week.
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
I've never used a down draft booth but I know a well kept cross draft booth will give you extremely clean paint jobs.
Following.
They wouldn't hire me at A&W so I became an automotive technician!
- unibody madness
Project is coming along sweet!
Did the 62 unibodies come with the rear cab mounts or did you ad them?
viewtopic.php?f=32&t=18944
Thanks. I believe unibodies have rear cab mounts. This one did and the parts truck I had did as well.
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
Had a chance this last weekend to do some metal work to the Unibody. I replaced the bed end caps. Originals were so beat up they were unusable. I chopped off a set of nice ones from the 62 unibody long bed I had as a parts truck.
- IMG-20151212-00458.jpg (254.87 KiB) Viewed 2010 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
- unibody madness
I think you were lucky on the cab mounts, unless Ford added them in later years, I have four 61 unis, and I had to add the set to the only one that has them. Great indicator is if the rears are rive,ted on or bolted on.
Love the color and the great job fitting the lwb corners on.
John
John
Looking great! Looks like the slick is a good starting point too.
I'm digging the colour, I just finished mine in the same. It looks brown in the pics but out in daylight it's great.
Had a chance to do some work today. I filled in the fuel tank filler hole. Filled in 37 holes on the firewall and the antenna hole. Almost time for some rough in bodywork.
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
After about a month away from it, had a chance today to do some more work. I mocked up the motor and installed the transmission cross member and built the lower motor mount to the frame. getting close to sending the transmission out for the rebuild and putting the rest of the motor together. the one pictured is a 289 I had in the back of the shop.
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
Here's a pic of the motor in and mounts finished.
- IMG_0009.JPG (368.03 KiB) Viewed 1808 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
Also mocked up the steering column. The Dakota front end puts the steering shaft at a much different place from the stock box and unit. Using a 67 Camaro column from the junk pile in the back. We'll buy a unit from Speedway Motors that's paint able and has a tilt column for the actual one.
- IMG_0007.JPG (350.08 KiB) Viewed 1808 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
I worked on the tailgate last week and did some metal work. Maybe this Friday some filler and primer.
- IMG_0008.JPG (216.41 KiB) Viewed 1808 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
It's been a while since I've been on here. Been busy building the engine for this unibody. It's a 302 bored .030, Procomp heads, Erson camshaft, Erson roller rockers and the Edelbrock Enduroshine Intake and 600cfm Carb. The color is a GM called cashmere. It's what the other half of the truck will be painted. I would post a picture but it says my board attachment quota has been reached.
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
