Got the front crossmember from the IC Dakota kit put in yesterday. Here's the update.
Everything was re-leveled after clean-up was finished. I actually use the 4' carpenter's level to make a nice place to put my shorter digital level. Everything here was within 0.1 degree of level from front to back and side to side. I chose to first clamp everything in place then tack weld it all at once. My concern was if I tacked the boxing plates in and had trouble getting the crossmember in, this would be an easier way of doing things. This is not how the instructions say to do it, just my way of doing things. Plan on using a lot of clamps. Little tacks to hold things, measure, read and make corrections if needed.
Once everything was in place, I tacked, checked my levels again then welded the majority of the welds for the boxing plates and portions of the crossmember to stabilize everything. A lot of jumping around to spread the heat and a couple breaks to let things cool. At this point you should be putting the lower a-frame rear mounts in place but I'm still waiting on the a-frames so I jumped ahead.
Once everything was solidly welded and wouldn't be moving on me, I placed a jack under the front crossmember and put a very slight amount of pressure on the frame. Again, not something in the instructions but it gave me piece of mind when I wacked the frame rail out. Didn't lift the front of the truck any, just basically took the slack out of the jack to keep anything from drooping when the cuts were made. I then marked out the cuts for the spring pockets on each side and cut one out. It gets a little scary when you cut the frame rail completely out. The spring pocket/upper a-frame mount went in place fairly easily and I tacked it in place.
Once everything checked out, I welded it about 75% complete and moved to the other side. Same process was followed. Everything went together nicely. You may notice the pics show the left side done and the right side cut out while my dialogue is just the opposite. I forgot to take any pics as I cut the left side. I was excited and concentrating so it slipped my mind until the left side was competed. That's why the pics show the left side done and the right side cut out in the background. I did the left, completed it then did the right. DO NOT cut both sides of the frame out at once. Just didn't want anyone to think that is what I did because the pics may be a little confusing
When it was all in place, I lowered my jack in front and everything was still within 0.1 degree of level every direction so I'm pretty happy with that way of doing things.
I have a small area on the lower frame rail that needs a little heat to close the gap between the frame rail and boxing plate. Once that is done, I'll finish weld everything. Ran out of gas for the Mig and oxygen for the torch so things came to a screeching hault yesterday before everything was finished.
I am also waiting on my Dakota parts so I haven't put the rear lower a-frame mounts in, they are just hanging in place in some of the pictures.
Will keep you updated as parts show up!
