Which rearend for CV swap on 62 uni
62unif100
Post by 62unif100 »
Hello fellas, I recently installed ifs from cv on my dads 62 uni,now my question is which rearend can i bolt on to get the 5x4.5 lug pattern? I will be using 05+ mustang rims as they are easy to come by.Thanks
Hunter's 64
Re: Which rearend for CV swap on 62 uni
Post by Hunter's 64 »
if your are keeping rear drum brakes you can have a shop take studs out ,weld it up and redrill to your specs. If it has a ford 9" you can redrill or you can buy new axles with correct bolt pattern... just a fyi if your going to redrill go ahead and buy new drums no reason to pay to redrill old used drums that will be shot in no time :2cents:
Danny
62unif100
Post by 62unif100 »
Is the 9" in it rite now same width as the front? we are trying to get as close as possible width as the front.Thanks
Hunter's 64
I think the 9" is a little narrower than the CV front end , you can use spacers in the back or order correct offset for wheels to even the track width. I don't know of another rear end that will swap into truck that's correct pattern and track width, sorry.
Danny
cwindsor
Post by cwindsor »
Things I have learned on my swap in progress...
03+ Crown Vic is way to wide....
I put my 9 inch back in and used 2 inch adapters that gave me a width of 65" Hub face to Hub face.
I also found out an axle flip lowering drops the back like 6 inches
