Does anyone use R11 refrigerant for anything anymore?
bobenhotep
Post by bobenhotep »
I have some R11 that was on my place when I bought it. Does anyone know what it is good for?
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
Re: Does anyone use R11 refrigerant for anything anymore?
Post by rickairmedic »
R12 is worth its weight in gold almost R11 not sure will check around tomorrow .
betfm
Post by betfm »
We used to use R11 to flush/blow thru R12 systems after a compressor burnt up and contaminated the lines and rest of the system.
In other words it was used as a solvent to clean the contamination out of the lines and the rest of the system.
It was cheaper than R12 at the time.
"I just need a bigger hammer"
Ed
1961 F250 Unibody long bed ,(Under construction)
You know now that you mention it I do have several cans of R11 flush in the truck DOH wasnt thinking of the flush kits :D.
Well Bob theres your answer :D we use it to flush systems :D. I usually use it when flushing an older R22 Lineset I am not changeing when I switch the system over to 410A and dont change the lineset for whatever reason .
bobenhotep
I was wondering because I have a 100 lb drum of it next to my shed, and another can in the shed. I think it is a 30# tank. It looks like an r134a 30# tank but is orange.
"The Iron Rhino"
-duraspark II/ HEI
betfm
Post by betfm »
Bob,
I done a little research since you wanted to know if there is any value to the R11.
This is link to ebay auction.
http://www.ebay.com/itm/R-11-Refrigeran ... 4ac228262b
I think you will like the answer--now to sell it!
Ed
bobenhotep
Thanks!
"The Iron Rhino"
-duraspark II/ HEI
