turn indicator- metal vs. plastic instrument panel
had several questions on how to change the 2 indicators in the metal panel to the 1 in the plastic panel.
(or the reverse)
it is very simple here is the factory wiring
take the 2 indicator lights out and plug in the one bulb socket
ezernut9mm
Sweden
Post by ezernut9mm »
interesting. i suppose it's the opposite to run the round speedo then.
yes for the 2 you would pull that out and run single wire bulbs.
ezernut9mm
Sweden
excellent. thanks.
any ideas on what to use to "isolate" the turn signal bulbs and high beam bulb? as in, the factory had some small pieces of cardboard tubing between the bulbs and lenses so the lights didn't "bleed" into the gauges.
knowwhatimsayingvern?
SLICKCOLLECTOR
Re: turn indicator- metal vs. plastic instrument panel
Post by SLICKCOLLECTOR »
THANKS.
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
