Duraspark/HEI ignition
bobenhotep
Post by bobenhotep »
I built my ignition system like the rest of the stuff on this truck. The idea behind the ignition system was to build something simple that worked, and was easy to get parts for.
9327
Parts used in this system
-msd blaster 2 coil
-computer heat sink (mine is from an old compaq computer)
-GM HEI module of the 4 pin variety (I ask for one off of a 78 chevy van if they ask)
-DS II distributor
-ring and spade terminals
-12 and 14 gauge wire
-screws
I am going to take more pictures and have a wiring diagram for those of you that might like to do this.
This is how I mounted the HEI module. The module is mounted to a computer heatsink out of a compaq that I bought in 2003.
The heatsink is screwed to the fender, fins down. The module is screwed to it, and a liberal coating of good heat sink grease, which I bought at Radio Shack, is applied between them, to transfer heat away from the module.
8982
This is how I wired it.
9328
Last edited by bobenhotep on December 31, 2011, 12:05 pm, edited 4 times in total.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
mrgoob
Post by mrgoob »
Thanks-I would be interested in that.
62galxe
Post by 62galxe »
heres a good diagram borrowed from the y forum.
http://www.y-blocksforever.com/forums/T ... hei+module
1963 uni PATINA BLUE
1965 short bed
bobenhotep
8982
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
9328
"The Iron Rhino"
-duraspark II/ HEI
The Big M
Post by The Big M »
My wife has an '02 Sonoma that uses the same ignition module, but it's mounted on a factory heatsink. I'm not sure when GM started using them, but it could be something to look for in a junkyard.
The computer heatsink is a nice cheap solution though! It should offer plenty of cooling. However, if you do find that the module is getting warm you could improve the efficency of it the heatsink by positioning it such that hot air can rise upwards freely, away from the fins. However, even without the full benefit of the fins, you still have significantly more surface area at work than the factory heatsink. Nice job! :)
bobenhotep
I thought about mounting it like that, but airflow under the hood goes through it, and I can touch it after driving and it is barely warm. I thought being able to quick swap it was more valuable than being able to remove more heat. any more cooling would be overkill.
"The Iron Rhino"
-duraspark II/ HEI
pikupmn
Re: Duraspark/HEI ignition
Post by pikupmn »
i just used a electronic ignition, distributor, an brain box out of a 80 sumthin bronco got them at the junkyard for $30 and i get to stay all FORD...............not saying anything is wrong with the way you did yours
1966 Long Box 5/8 ton wha.gif
2000 Road King
bobenhotep
I thought about doing that, but I had most of the parts already. The 4 pin hei will work on just about anything. I have seen them on old imports that you cannot get modules for anymore, as well as on a ford.
"The Iron Rhino"
-duraspark II/ HEI
sully5
Post by sully5 »
I did this conversion and it works like a dream.
bobenhotep
And I still have this setup, no problems.
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
This is the setup minus the tachometer
11312
"The Iron Rhino"
-duraspark II/ HEI
Hey Dan, I like your HEI setup. Was wondering about what year of DSII dizzy I should use for my 300 six. It is an 81 engine, but I figured about anything would work. Any suggestions on what vehicles I should look for when I go after one. No junk computers here, so looks like a trip to Radio Shack for me for a heatsink. Did you put
the grease between the module and the heatsink? Wasn't clear on that one. This looks like a great way to get a cheap, reliable ignition. Shoot me a PM if you would. Thanks. TR
bobenhotep
My distributor is the original one for a 1980 model, because my engine is out of a 1980 model also. I would just use any duraspark with the single vac advance canister.
"The Iron Rhino"
-duraspark II/ HEI
bobenhotep
Also, do not use the ignition circuit "as is" to power the module. There is a pink wire under the dash, and it is a resistor wire. It will cause the module to do odd things. Replace the pink wire with a regular wire so that the module/ coil get full 12v. I will rewrite the stuff up top to reflect this to avoid nonsense in the future.
"The Iron Rhino"
-duraspark II/ HEI
NUMA NEWBERN
Post by NUMA NEWBERN »
http://performancedistributors.com/ makes a HEI for the Ford straight six, I've seen them on another site but you will play hades to find it on there site, may have to email them directly about such
NUMA NEWBERN
I have a 1965 with it appears to be a original 6 cylinder, I was comtemplating a electronic conversion module etc. BUT I love the GM module, will these Duraspark distributors fit the 65 engine?
ALSO
A suggestion INSTEAD of the heat sink, the object is disaparing heat right? Then why NOT bolting the module to ANYTHING flat? Instead use studs or in other words LIFT the module by the mounting bolts UP say a inch or so where air can circulate UNDER the actual module base?
NUMA NEWBERN
NUMA NEWBERN
NUMA NEWBERN
List of HEI distributors for Ford 6
http://www.restorationperformance.com/s ... Categories
