Duraspark/HEI ignition
NUMA NEWBERN
Re: Duraspark/HEI ignition
Post by NUMA NEWBERN »
NUMA NEWBERN
TSP Ford Inline 6 HEI Distributor
High quality brass terminals and a protective plastic dust cover that encapsulates the 65,000-volt coil. A new cast-aluminum housing featuring a machine polished finish contains new bushings, mainshaft assembly, and a hardened steel gear. Our HEI includes high-output module, centrifugal advance components, and adjustable vacuum advance canister.
170 from mid1965 and up, 200,250ci (4.1L engine) Inline 6 engines
All 200 and 250ci motors with 5/16 hex shaft
Does not work with 144 or 170ci with 1/4in drive
Features a hybrid vacuum advance adapter for rubber hose or hard line advance
Adjustable vacuum advance
Stock Replacement
E-Z One Wire Hookup
Hotter Spark for more power and efficient fuel management
Faster Engine Starts
Allows for a wider spark
Item # : JM6527
Price : $204.95
Sold out. Temporarily not available !
http://www.topstreetperformance.com/eng ... ibutor.php
bobenhotep
Post by bobenhotep »
I uploaded the originals to photobucket so I could put them on here.
This is without tachometer
This is the with tach version
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
