61/62 f100/250 2wd turn signal switch
pics of parts and assembly of the 1961-62 2wd f100/250 turn signal switch and horn actuator.
disassembled:
collar inside:
spring loaded plate:
turn signal switch and wiring harness adapters (single bullets to triplex plug)
horn actuator:
reassembly:
switch installed
horn installed
spring, retainer and washer for plate.
plate assembled.
washer on bottom of lever pivot, fat end of spring down.
complete:
difference between 61/62 lever and 63-66 lever.
61/62 on bottom.
cookster4495
Post by cookster4495 »
Thanks on the how-to !!!! :thumright:
1961 f250 4x4
1964 f250 crew cab
don morris II
Post by don morris II »
mystery solved :D thanks
FORD, FAST, FLYING, FIRST, ALL START WITH F IS,NT THAT "SLICK"
unibody madness
Post by unibody madness »
hey iceman, i think it is a build number or model (maybe tranny) specific deal.
i have been lucky enough to have owned or been a part of five 61s.
my sons three on the tree step, and my three tree uni, have a different,plastic switch mounted from the left with the lever screwed direct to the switch.
my longbed born as a four speed on the floor, and my first slick, short bed uni with a floor mounted four speed, both had the metal plate with with the lever,and the switch mounted on the right.
my latest is also a three-tree but have not had a chance to remove the steering wheel
if you come up with an extra spring/washer/clip, let me know, my longie came w/out and that is what lets the detent work thanks
john
charliemccraney
Post by charliemccraney »
Will the collar pictured mount on a column shift column? I haven't used the column shifter since I've had the track. That will clean it up a bit. I know where there are some 4 speed slicks that may have what I need.
charliemccraney
I have answered my own question. The answer is yes!
William-in-St George
Re: 61/62 f100/250 2wd turn signal switch
You should be able to use an "E" clip available at most parts/hardware stores. Looking at this I think possibly a W/W pivot clip might work?
William-in-St. George
