Satin or gloss under the hood?
I've started cleaning up and priming under hood small parts suches as latches, brackets, hinges etc. I'm blasting the crud and corrosion off for a smooth surface. What is the consensis on black under the hood, satin or gloss? I'm leaning towards satin. I initially started in Gloss on my Galaxie but switched to satin cause I thought it looked cleaner.
BUY FORD, SUPPORT YOUR LOCAL MOTOR COMPANY!
65 F100
66 F100
65 F100
66 F100
Semi gloss is my vote even though you didn't make it as an option. Semi gives you both of what you can't decide on lol. Seriously though, gloss will show every scratch and detail, flat will show more dull spots in certain areas (sometimes) and Semi will have both and be a good in between.
That's just my oppinion though.
- 66fordtrucknut
- DV65CustomCab
- dotcentral
